IR Thermometers
    Re: IR Thermometers
    adam, you know that the ir that bill just purchased is brand new. it's either user error
    or a flaw in the electronics.
    your tubing cutter is just plain worn in.
    are we still challenging bill to a tubing cutter race
    his stolen miwaukee 12 volt cutter against our #15 ridgid tubing cutter
    bill if you can beat me in my own game, i'll buy you a new one
    but when you lose, you owe me milkshakes at every meal and yes we will have to compete wednesday so i can stack the shakes up. 3 a day wednesday through sunday afternoon
    you in or out
    3 pieces of 1/2'', 3- 3/4'' and 3-1''. m,l,k. 9 pieces total to cut.
    No vises set up, right?
      Re: IR Thermometers
      Rick,they're not made for speed.Anyone can beat'em.
      You want speed?Use a battery circular and carbide blade(better wear eye protection).
      They're for workin in a 18" crawlspace doin a copper repipe.Layin on your belly.Or angle stoppin 10 houses a day in tract work.
        Re: IR Thermometers
        Mark: How can you dial in emissivity without knowing the actual temperature of the surface to start with
        Bill
        It came with a book which told you which rocker pins needed to be set in which position depending on which material you were measuring. If I was checking a A/C I would just set the rockers for painted steel.
          Re: IR Thermometers
          you want in on the contest too
          i'll take on bill and adam will take you on.
          this will be in the open. free hand. not in a cramped up against the joist work area.
          just a speed cutting contest holding the pipe free hand.
          adam, what you drinking
          it will be like taking candy from a baby
            Re: IR Thermometers
            Actually, none of the contests interest me at all. Hope that doesn't disappoint.
            Just thinking about how Mr. Bill will do against you with his power cutter.
            Meeting good people with similar interests is the most interesting to me.
              Re: IR Thermometers
              Okay guys let's ease up on the kid from the short bus. I have asked you before to respect his limitations.
              Thanks-Mark
                Re: IR Thermometers
                Thanks-Mark
                Sorry,
                I forgot again.
                • #23
                  Re: IR Thermometers
                  I tried a ridgid one and returned it after only a few days and got a fluke instead. I am very happy with my fluke and use it for everything from checking for hot/cold cross-connections to discharge air temps at ceiling diffusers and radiant tube heaters. It has made lots of troubleshooting tasks easier.
                  • #24
                    Re: IR Thermometers
                    Shock, what was the reason for returning the Ridgid and spending twice as much for the Fluke?
                    • #25
                      Re: IR Thermometers
                      $300.00 Ra tech about 5 years ago. it rocks. Here are some uses You might not think of.
                      Race track ,ferriers hit each hoof while shoeing. High temp.= hoof disease.
                      Large 3 phase motors in factory's. Hit bearing ends. change hot ones before failure.
                      Mine can hook up a lap top to record history of components. MY FAVORITE, when the grandchildren come. Have them hit the freezer, stove ,light bulbs, Grampas BALD HEAD!
                      Try the Kids, they have a ball, and learn. One more,on Large trucks! They hit the radiator cores to find blockages! NO RICK , K-60 WONT HELP HERE!
                      • #26
                        Re: IR Thermometers
                        I've got the fluke.
                        I've found leaks under slabs, both hot water and chilled water. Of course, the sweating floor helped with the chilled leak.
                        It also saved my arse when I pulled my boat to table rock lake last summer.
                        I replaced all 4 sets of bearings and races. The morning I left, I couldn't sleep so I got up around 4AM and hit the road.
                        I stopped 20 mi into the trip and found one hub getting hot. I was laying along the side of the interstate, in the dark with a thunderstorm approaching, trying to figure out what was going on. The last thing I wanted to do was tear down a wheel in the dark. That's when I noticed the temp got hotter as I swept the therm. out towards the brake drum. I adjusted the shoes in and it cooled right back down to temps like the other wheels showed.
                        If I hadn't had it with me, I probably would have wasted a bunch of time taking things apart.
                        They are a good piece of equipment to have in your tool box.
                        • #27
                          Re: IR Thermometers
                          Almost every day!
                          • #28
                            Re: IR Thermometers
                            I used mine to find a brake caliper that was hanging up intermittently. Compared the rotor temps and found the dragging caliper right away.
                            Rotor temp was almost twice that of the other three.
                            At work we use them every day to monitor equipment breakers, check for overheating relay coils, and many other uses.
                            • #29
                              Re: IR Thermometers
                              The fluke actually felt a lot more durable for one thing, I just did not like the feel of the Ridgid tool, and the fluke has a longer range of accuracy.
                              Usually I prefer ridgid handtools over other brands, but for electronic testers, meters, etc. fluke is all I will buy from now on just based on experience with other brands.
                              • #30
                                Re: IR Thermometers
                                1959 Eichler Radiant. We have this home. I cranked up the boiler,and found a 6 degree high where the 3/8" copper lines were. One side had settled 3 ". Jacked it up and welded off chance helicales. core drilled between lines and poured fly ash grout in void.
