Help me out here
  • Help me out here
    So my furnace quit working on me. I have a 10 year old Bryant 355MAV. It sequences fine, the hot surface ignitor glows and gas valve opens but the gas does not ignite. What is up with that?
    Re: Help me out here
    replace ignitor not getting hot enought to light gas
      Is the gas turned on
      Do you hear the gas or just the click of the valve...
        Thanks Jeff, I wasn't sure if that would do it but that is also the conclusion that I came to.
        And yes the gas is on thank you Bill.
          I have never run into an HSI that glows but will not light the gas flow.
          I was just starting the troubleshooting at the beginning by asking about gas flow
            Same here.
            Check the voltage at the gas valve while the HSI is glowing.
              I have. Extremely rare though. Once, maybe twice I have seen this.
              Andy
                one way to prove it is with a long lighter as you here gas valve open lit it to bring on flame . I have seen it more than eought glow and not lit gas
                  14 years in service work and I can't remember a HSI that glowed but would not ignite proper gas flow...
                  No way would the first thought be to "change out the HSI" That would be at the bottom of the list if I could see the glow.
                  Change out the HSI without more information is just parts swapping advice
                  Rule out the simple first then get to the weird 1 in a million faults.
                  Mtman1100 will let us know how his issue works out...
                    The first thing I would check for on that particular furnace is a blocked combustion air inlet. You can have fuel and ignitor but if you dont have air you wont get fire. My money is still on the HSI though.
                    Andy
                      Andy
                      It's probably placement more than it was temp.
                        I agree with the venting being an issue on that furnace. Try it with the burner box door off. If still nothing, try it quick, with the exhaust boot loose. If still no, check gas flow or at least if you smell it. Slightly bending ignitors twords the burner crossover and tword the center of the main opening might help. Also, especially if the intake is drawing from the basement, or drawing outside near a source of moisture, rust on the burners may stop it from catching. This furnace's ignition is very finicky.
                        Don't forget the $1500.00 to upgrade it to 95%. The venting is already there.....if properly sized. Might be worth thinking about this, or next year.
                          OK, so are we talking about a spark ignition system or an HSI??? I know for sure an HSI will not bend...
                            Man I gotta quit posting so early in the morning after a long night at the bar. If venting was the issue more than likely the pressure switch wouldnt close, which wouldnt send power to the ignitor or gas valve.
                            Ran across a few where placement was the issue. The ones Im referring to had zero adjustment on the placement.
                            Andy
                              Ok, good point. I refer to the ignitors bracket. Ruudguy made me remember that yea, it may be a zero adjustment set up, I can't remember. Still, that often works on yorks for example where placement is the most criticle I've seen.
