Sterling Overhead heater
  • Sterling Overhead heater
    Hi Looking for a gas valve for a mid 80's sterling overhead space heater 150.000 btu valve is a honeywell V800A7010
    Re: Sterling Overhead heater
    Very easy to find. Most likely has a 3/4 inlet and outlet. Just get a valve for a standing pilot or intermitent pilot. White-Rodgers and Honeywell make universal valves.
      Hi Do you need to worry about the wires for the safety swithes or just bypass
        Aaaaaaahhh.
        Did he just say "bypass safeties"? Well, that's why some advice should not be given on here.
          Please....do yourself a favor and call a liscenced gas-fitter.
            Hi Do you need to worry about the wires for the safety switches or just bypass
            If you like the possibilities of fires and explosions you do not need to worry.
              Hi Called licensed heater man and he said we needed a honeywell V800A7010 valve to fix it but heater was to old to find part so I thought if I could find one on this sight maybe someone had one but no heater to put it one.The heater is in really good shape no rust.If we can't find the right gas valve than it will have to be a new heater.Thanks
                hi Went to the honeywell site found the new part #for the gas valve and grainger supply had it ups and all $121.00 lot less than 1450.00 for new heater Thank you for the replies
                  Hi Have the heater fixed now when it lights the gas line sings or screeches 3 other heaters in building are quiet. any ideas?
