Honeywell RTH230B Thermostat Wiring
  • Honeywell RTH230B Thermostat Wiring
    I'm attempting to replace a Robert Shaw electronic programmable thermostat. The following six wires are connected as follows in the unit:
    Green wire to G terminal
    Orange wire to O terminal
    Blue wire to B terminal
    yellow wire to Y terminal
    White wire to W terminal
    Red wire to jumpered RC & RH terminal
    To be honest I don't know what type of system the HVAC unit is (i.e. heat pump, central air, etc - nor do I know how to tell by looking at it).
    I have a Honeywell RTH230B electronic thermostat. Can this unit be used with the wiring above? If so, how are the wiring connections made? The honeywell unit has the following wiring connections:
    Rh
    Rc
    W
    Y
    G
    Thanks
    Spakman
    Re: Honeywell RTH230B Thermostat Wiring
    The fact the you have O and B terminals could indicate you have a heat pump. Anyway, you have to find that out, because the RTH230B does NOT have heat pump capability.
    Post the model number of your outside unit .
