Biasi good-bad?
  • Biasi good-bad?
    FIL is considering a Biasi boiler.
    Anyone have any experience with this brand good/bad?
    Re: Biasi good-bad?
    Gene, we install quite a few Biasi boilers. I like them. I'm not thrilled with how the controls mount but it's not enough of a problem that I wouldn't sell them. They are efficient and reliable. Make sure to use the Riello burner with it if using oil.
      Re: Biasi good-bad?
      Installed a B10-3 in my own home with a Honeywell AQ2000 control and am very happy 2 seasons later. I replaced the stock aquastat with a hydrostat 3150 combo aquastat LWCO. The Biasi is a good solid 3 pass design and is a cinch to clean. Mine is with the Riello, but a friend of mine had the same setup with the Beckett NX, and its a bit quieter, and you have the option for outside combustion air.
      I added a Field Controls OVD-6 to mine this year as well.
        Re: Biasi good-bad?
        Originally posted by nhmaster3015 View Post
        gene, we install quite a few biasi boilers. I like them. I'm not thrilled with how the controls mount but it's not enough of a problem that i wouldn't sell them. They are efficient and reliable. Make sure to use the riello burner with it if using oil.
        well said i feel the same!!
          Re: Biasi good-bad?
          I have a nice brand new Biassi Riello with an indirect, tigerloop deaerator, hydrolevel 3150, taco zone control topped off with a nice Intellicon HW+ economizer. All said and done cost around $3,000 self installed and compared to the old crown boiler with tankless I saved about 450 gallons of fuel (Down to about 850 annually on long island, 2,500 ft2 foot print) I plan on installing the Field Controls OVD-6 and not sure what more I could do to squeeze a little bit more "greeness" out of this bad boy anyway here are some pics....http://www.flickr.com/photos/25250512@N08/
          Any suggestions for additional tricks I can add to this are encouraged!
            Re: Biasi good-bad?
            What's with all the pipe insulation, is that to hide all your joints?
            It looks good to me, but I don't know jack about boilers.
            All I know is, if it gets cold turn up the thermostat. If it's still cold check the fuel tank. If it has fuel and it's still cold, call Dave at D and D Heating.
