Trane Weathertron (Baystat 339) to Honeywell RTH2410
  • Trane Weathertron (Baystat 339) to Honeywell RTH2410
    I just replaced my old Trane Weathertron (Baystat 339) mercury thermostat with a Honeywell RTH2410. Everything appears to be working fine, but I'm concerned about a few things... I had to tape off the Blue and Tan wires because there were no connections available on the new Honeywell. Also, the instructions told me to put both the Black (X2) and White wires into the Aux connector on the new Honeywell. I have a heat pump with auxillary electric heat.
    Does that seem right? Should I have purchased a more expensive Honeywell thermostat where I would have separate connections for Black (X2) and White as well as somewhere to connect the Blue wire (instructions on more expensive Honeywell thermostats say to connect the Blue wire to "C").
    Any thoughts? Here's the breakdown of which old wires I connected to the new Honeywell RTH2410 (old - new):
    R - R
    O - O/B
    Y - Y
    G - G
    X2 - W/AUX (combined with W)
    W - W/AUX (combined with X2)
    B - Taped off and tucked back into wall
    T - Taped off and tucked back in to wall
    I appreciate any help / advice you may be able to provide.
    Re: Trane Weathertron (Baystat 339) to Honeywell RTH2410
    I've Googled the Honeywell RTH2410 and came up empty.
    If it's working I wouldn't worry about it. I installed a digital heat/cool tstat once that was only a 4 wire, it didn't have a C common terminal. Thinking it was a Robertshaw.
    I use the White Rodgers 80 series Tstats exclusively. Very reliable, easy to wire, and program.
