Boiler Questions/concerns
  • Boiler Questions/concerns
    Hey Guys, newbe to site, Looks great, gonna dig deeper and check out. Anyway: I just installed a new boiler. The water pressure is between 25-30 psi. Too close to max 30. Isolated autofill valve to eliminate that. Still climbs. Any ideas??? Also Boiler seems to loose temp rapidly. Approx. 10 deg. in 15 Min. causing boiler to cycle because of 10 deg. differential on high limit. Wondering if this could also be program concern on aquastat not allowing enough temp drop.. Thoughts??...Curt
    Re: Boiler Questions/concerns
    clean out the screen in the auto feeder ,you should only have 12 to 15 psi in the boiler
      Check your expansion tank also! Any type of controls on it we should know about?? tekmar controls, outside resets,inteledyne?? Somthing?
        Sounds exactly like a flooded expansion tank or a burst diaphragm in a new tank. Is this a combi system or do you have an indirect fired Hot Water Tank attached
          gassy. it looks like nut has been fired or something. 3 weeks no answer. maybe they hired a pro to remedy situation. lol. breid...............
            Could very well be my friend, cheers
