semi-rigid aluminum ducting
  • semi-rigid aluminum ducting
    The semi-rigid aluminum ducting I want to use to get through a tricky, curvy 2-foot space is 6" x 8' but is compressed down into a 28" length. My question is: when using this material do you stretch it out? That is, I could use the length as it is without cutting, but I'm wondering if I should stretch it out to take out and just use 2 feet of the 8 foot length. Sorry if this is a stupid question and thank you in advance.
    Re: semi-rigid aluminum ducting
    You can pull it out to just what you need
