Weather King 90% Furnace
    Re: Weather King 90% Furnace
    Don't know how your Cook County Community and Economic Development Association works, but usually a government program is just a money deal. They do not contract for the work, or take on any warranty or service responsibility. Is this different in your case?"
      The CEDA program is a government program that does have warranties and must follow-up on service problems.
        Has that unit been fixed yet?
          No. CEDA is giving me a really hard time.
          I was told that one of the causes of my problem could be the intake/exhaust pipes that are supposed to be about 12" apart mine are right next to one another and one is only slightly higher both pointing down.
          Anyone know anything about this?
            That can certainly be an issue. The last thing a heater wants is exhaust fumes being used for combustion. This can cause incomplete combustion in the chamber and lead to soot buildup on the heat exchanger over time. A clogged exchanger can create a pressure switch failure.
            There are vent termination kits that get around this by the way they are designed. If you just have 2 pieces of pvc stuck out and turned down, then that needs to be corrected. The 12" seperation you mentioned is the minimum.
              Originally posted by Kevin Jones View Post
              The 12" separation you mentioned is the minimum.
              Is there a standard for how many inches these pipes should be separated?
              We don't even have a 6" separation on our system and both pipes are turned down.
                Yes the satndard for your equipment is listed by the manufacturer in your installation manual. Rework the intake and vent to conform to those specs.
