Weather King 90% Furnace Page Title Module
  • Weather King 90% Furnace
    A government program called CEDA installed a new Weather King 90% furnace and since the day it was installed we have had intermittent problems with the fan turning on but not the burners.
    No one from CEDA believes that this is happening so we can't get it fixed.
    Everyone we talked to claims they have never heard of this.
    I have an 85 year old parent that is suffering because we can't solve this problem.
    Has anyone ever heard of this?
    Any ideas as to what could cause this?
    Thanks
    Re: Weather King 90% Furnace
    Could be the fan control board or thermostat. Something is energizing the fan relay.
    James
      CEDA has already changed the thermostat to no avail so it might be your other suggestion the fan control board.
      Thank you.
        Pay a good company to do a maintenance cleaning on it and I'll bet you the problem goes away. How old is it?
          It's only 1 1/2 yrs old and it had this problem from the beginning so I don't think a cleaning will do it but thank you for the suggestion.
            Is it doing this on a call for heat or is it just turning on and off on its own?
            DIRTFT
              It does it intermittently when the system calls for heat. It has no air conditioner.
                Post model and serial numbers. I can get some info.
                DIRTFT
                  You have a call for heat and the fan comes on with no burner fire...I would take a look at the pressure switch.
                    Thanks
                    This is a problem with the fan control timer on the main board. The control board will need to be changed. It is probably still under warranty.
                      MAKE: Weather King
                      MODEL: 90RT07EES01
                      SERIEL: GY5D302F470804597
                        Getting CEDA to take me sseriously has been a problem. I will mention your suggestion to them.
                          Any rheem contractor can replace the board under warranty.
                          DIRTFT
                            What is your altitude? The fan pressure switch links back to the board. It sounds more likely a ps than a board. Allthough either is possible.
                              I'm in Chicago altitude isn't usually a problem here, but thanks.
