condensate drains
  • condensate drains
    When did they start using lime rock filters! About a 15 Year old furnace ,no filter and they used liquid tite elec conduit from furnace to condensate pump! Instead of b vent on tank W.H. they used allum dryer hose! Will fix soon
    Re: condensate drains
    Are the drain lines that the condensate is running to cast iron?
      Yes , My heat Guy comes today. I'll have him change out a lot of Garbage. New condensate filter, Pvc to drain [ they have 1/2" vinyl hose for 30' to drain] B vent on W.H. instead of allum. dryer hose .
        If you have cast drains then the condensate will eat the drain pipes in time. You will need an acid neutralizer for the condensate line.
          Furnace is 20 years old. My heat Guy may replace it all. His work is good and also His prices! With the fed. tax break It's the wise decision.
