Carbon Monoxide Poisoning
    Re: Carbon Monoxide Poisoning
    Here's another personel monitor that checks O2, CO, H2S, and SO2 levels.
    http://www.transcat.com/Catalog/prod...tm_medium=base
      it'll check one of the above per unit
      you have to buy the monitor for the gas you want to test for
        You are correct.
        Looking at their web site it does say it is a single gas detector.
        The instruction sheet does not read that way (I'm holding it in my hand reading it now).
        It makes no mention that the device is a single gas detector. Since it contains information
        on alarms, operation, and calibration for all four gases it could easily mislead someone into
        thinking it detects more than one. There are no words in the instruction sheet stating it
        detects only one gas. The information is not seperated into sections dealing with each gas,
        it's all mixed together which is confusing.
        Detection ranges:
        H2S: 0 to 100 PPM
        CO : 0 to 300 PPM
        O2 : 0 to 30% by volume
        SO2: 0 to 100 PPM
        Calibration:
        H2S, CO, SO2 - Not Required
        O2 - Self-calibrating
        GAClipExtreme_Manual(D2139-9-EN).pdf
        This detector is made by BW Technologies, a div of Honeywell
        www.gasmonitors.com
        USA: 1-888-749-8878
        CA: 1-800-663-4164
        Questions? email them at: info@gasmonitors.com
