Vent Temperatures?
  • Vent Temperatures?
    Just curious as to what a "good" vent temperature would be for Air Conditioning?
    What about heating with a heat pump? Natural gas?
    What's considered a desirable, efficient, temperature for the different seasons at the outlets/vents?
    Thanks.
    Re: Vent Temperatures?
    From experience what I find is a variety of different discharge air temps. Duct, blower speed, condition of the equipment,conditioned space, all these factors have an effect on air temps.
    Short answer.
    For cooling 50-60.
    Heat pump heating mode around 100.
    Nat. gas furnace around 120.
    As for desirable temps. As warm and cold as possible within the heating and cooling unit specs.
    What I find is poorly installed and sized duct is the biggest problem concerning air distribution problems. Use flex duct sparingly. Do the duct right, everything else will fall in place.
    James
