Dryer Vent/Duct
  • Dryer Vent/Duct
    Not sure where to put this. When running the dryer duct hard pipe, do you just tape the joints on that puppy?
    Thanks.
    Re: Dryer Vent/Duct
    You're only supposed to tape it, cause using screws will catch the lint.
    (in our code)
      Re: Dryer Vent/Duct
      (in our code)
      That's what I thought as it makes common sense to me. You use the same foil type tape approved for ducts, right?
        Re: Dryer Vent/Duct
        Yes I use foil tape, as it's better than using duct tape. But some body else might be using something different.
          Re: Dryer Vent/Duct
          Thanks.
          I have 5 Huebsch dryers with 9" vents. I screw those puppies together. Residential, I use aluminium pipe and silver tape. Thought about using a Malco snap lock tool on the joints also. Tape usually holds okay.
          James
            Re: Dryer Vent/Duct
            i believe that pop rivets are acceptable. the idea is the rivet will peen over if it's installed with the proper length rivet.
            i don't think tape is a lifetime joint.
              Re: Dryer Vent/Duct
              Neither is ProPress. Let's fight.
