gas valve question?
  • gas valve question?
    does anyone know what the "set" position on a gas valve is for? from left to right my gas valve says "off-on-pilot-set".
    Re: gas valve question?
    Sounds like you have the Robertshaw gas valve or Intertherm. SET position is where you hold the lever to when lighting the pilot. After the pilot is lit and the thermocouple warmed up you slowly release it back to PILOT setting.
    FWIW, the Robertshaw 7000 series gas valve had a huge recall.
    http://www.toolbox.invensyscontrols....call/7000.html
      Sounds like one of those robert shaw valves where you have to move the lever to the set position when lighting the pilot. About a minute after lighting the pilot you move it to the pilot position, if the pilot stays lit you move it to the on position.
      Sort of like the most valves where you have to hold the knob down while the thermocouple heats up.
      James
        Good to know about the recall. I haven't installed one these "stick shift" gas valves in years.
        I've never been a big fan of robertshaw products.
        James
          thanks guys, it worked. i was a bit confused for awhile. the valve was installed beginning of this year so i didn't think there was any chance the pilot oriface was blocked. it's been turned off the entire summer. i was setting it to pilot and pushing it down with the match near the pilot oriface and nothing was happening. i don't know what i would do without the people on this website. y'all have helped me out, many times over. thank you.
