Need some help with replacing Thermostat
  • Need some help with replacing Thermostat
    Hello,
    I have a old Carrier Heat Pump Thermostat and would like to replace it with the Honeywell RTH2410B. On my old thermostat is a W2 wire, but the RTH2410B has only a W/AUX and not a W2 plug/connection.
    Can I put the W2 wire in the aux?
    Picture of my old themostat:
    PDF Manual of the RTH2410B (Page 6)
    Thank you
    Re: Need some help with replacing Thermostat
    What does the instructions for the new tstat say?
    If it were me I'd try it. Since W2 is for the aux heat it's most likely one in the same.
    James
      It says "Heat pump with auxiliary/backup heat"
      See here page 1:
      http://customer.honeywell.com/techli.../69-2382ES.pdf
        Pages 7 & 8 explain it. You need to put the W2 wire on the W/Aux terminal.
        James
          Great. Thank you. I did stop reading after page 7.
            You're welcome
              [QUOTE=MAD King;321267]Hello,
              Yes,That should work just fine, good luck, have a good day]
              Thank you[/QUO
              let me no if it works
                [QUOTE=JoeD;324688]
                Originally posted by MAD King View Post
                Hello,
                Thank you[/QUO
                is this working?
