code question
  • code question
    getting a sewer smell in a building and think it might be that the stack is to close to the rooftop unit when the wind direction is blowing towards the rooftop unit?
    Thoughts?
    Re: code question
    I believe it is a minimum of 10' to a fresh air intake.
      Re: code question
      Thoughts?
      I would say that vent should be at least 12" off the roof if not higher but I think it would be a streach for the sewer gas to be pulled back in that far but you never know I would try raising it myself and if your going to raise it about 2' to 3' wont hert
      SMELLS LIKE $$$$$$ TO ME
        Re: code question
        Yes but in chicago they let us get away with that if the vent is higher then the fresh air intake if I am not mistaken cause I have had to go raise them alot befor for that reason
          Re: code question
          The separation is usually 10' horizontally or 3' vertically. I just am not sure if there is a fresh air intake on that side of the unit.
            Re: code question
            Yea been trying to finger out where the sewer smell is cumming from inside the building with no luck and tried everything.This has been going on for years with a number of plumbers trying to get on top of it with no luck as well.
            Pulled up to the business today and as soon as I got out you could smell it.
            There wasn't any man hole covers around either?
              Re: code question
              It is possibe the ducts are not properly sealed where they go through the platform. Perhaps a smoke test while on high speed would be a way to test it.
                Re: code question
                Smoke test the sewer system and rule that out. I was thinking the same thing with the place I just smoke tested and it turned out they had two open pipes.
                  Re: code question
                  Thoughts?
                  In KY that would NOT pass code. Plumbing vents need to be a minimum 10 feet from any intake, on an HVAC fresh air hood in this example. One solution to this is to add on to the vent pipe with a coupling and add at least 5 feet to it. May not be pretty but inexspensive solution to your problem!
