honeywell pro 8000 installed but only heat
  • honeywell pro 8000 installed but only heat
    Hello there,
    I got a new thermostat TH8110U1003 today for my upstairs.. this is the second time I upgrade the thermostat to different brand.
    the current settings with (Ritetemp) thermostat is (heat pump without aux).. so the the issue is that I put the same settings for the honeywell and it blows hot air on cool..
    I tried putting it on hold, changing temperatures on schedule moving the system from cool to heat or vice versa.. no success..
    picture of current thermostat
    settings for current thermostat
    the honeywell pro 8000 settings that aren't working correctly..
    would really appreciate it if someone can give me a hand..
    Re: honeywell pro 8000 installed but only heat
    Show a picture of the wiring on the Honeywell VisionPro
    Double check your jumpers
    Go through the software setup settings very carefully. It's a great thermostat but it's definately not Plug and Play
      I think I figured it out.. for the system settings it says #170: System type:
      changed from 1 into 2.. now its blowing cool air and i like it.. the only question is what should I put in #190...
      in the winter I use the heat with (heat pump without aux)
        let me know.. thanks
          Find out if your heat pump reverses on heat or on cool/
            how do I find out?
              If its blowing cool when turned to cool and blowing heat when turned to heat, 190 is set correctly.
              Andy
