Primary secondary piping
  • Primary secondary piping
    Most of the new Mod/Con boilers are calling for a primary/secondary piping arrangement in their literature using two pumps, one on the primary and one on the secondary. I was curious how many actually use this set up when installing the new Mod/Con's compared to the standard one pipe/one pump system. I've talking to other professionals who are installing them without using primary/secondary. Any thoughts on this?
    I was talking to a rep yesterday for a certain boiler company and he said they most likely wouldn't void the warranty if you didn't use the primary/secondary but they do specify using it... "most likely" seems a little dangerous to me.
    Re: Primary secondary piping
    You have basically three choices. Primary/secondary which is tried and true and somewhat expensive and time consuming. You can go with injection which requires 3way zone valves or a hydronic separator and VFD pumps which is by far the easiest. Go to Caleffi's web site and download the Idronics series. They are free and will lead you through all the variations and logic. Remember that every job is different and will require different stratagies.
      Just had some training the other day at my local wholesaler for Mod/Cons. This specific company requires that the mod/cons be piped using primary/secondary. He said it could void the warranty but "most likely" it wouldn't. I was just curious how many installers actually use this method.
      Ran into three just recently while working on something else and all three were not installed using the primary/secondary method. They were installed using a basic two or three zone loop system.
      I just don't see the having the extra expense of running a second pump if you don't have to.
      Thanks for the website I'll check it out.
        here so pictures of a primary/secondary piping arrangement
        this one you can see the zone pumps and the main loop pump
        this one you can see the boiler pump injecting into the main loop
          here is another one
            we've been primary-seconday with injection on the new systems we've put in recently.
            In our part of the world, returns can be very cold at the start of a call for heat, so it's nice to protect the boiler a little.
              Curious, do you usually leave that much pipe exposed (not insulated)? There would seem to be a lot of radiation surface with those long manifolds and all the exposed branch piping. It will warm the room yes, so the heat is not 'lost' altogether, just doen't seem too efficient.
              Nice job on the layout and soldering looks good too, no runs, drips, or wipe smears.... just the way it should be.
                I only insulated heating runs if it calls for it, but never the piping at the boiler, unless someone has the potential to rub up against it and burn themselves.
                  thanks for all the kind words about my work i like what i do and put my name on all my work
                  Flux has the same thought as i do with some one getting burned . in the last picture there is no heat in that room ot the room on the other side of the block so to help keeping the room dry and heated we dont do it
                  there is not all that much heat loss off the pipes .b
                  with the condensing boilers you cant shock the boilers so the looping system works good ,and also for large cast iron boilers also
                    I was thinking the same thing Charlie. There isn't that much heat loss from pipes, and on a traditional boiler whether it's cast iron or steel matters more.
                      Hvac hawk,
                      Very nice piping layout and installation. You can tell when a plumber takes pride i what he does.
                      Jason
                        Originally posted by Crowfoot View Post
                        Hvac hawk,
                        Jason
                        Thanks
