AC won't turn on
  • AC won't turn on
    The ambient temp is 84, I set the Tstat at 75. I even set the fan to turn on, not automatic. The breaker is good, and still on. I check and turn to the heat, at 86, still nothing run. It was working just fine, in the winter. The unit doesn't turn on for a couple months because of the spring. Now it's hot, so I turn on the T Stat, and it doesn't work. What else should/can I check?
    Thanks in advance,
    Tea
    Re: AC won't turn on
    Is the furnace blower access panel installed correctly?
    James
      as James said, make sure the doors are on properly, there is a switch that gets engaged by the doors. if that isn't the problem there's usually a little 3amp twin blade fuse on the control board, check it. if that isn't it, it really is time to call someone with the right tools to check things over.
        I agree this has to be related to the access panel door. 90% of the time that is the issue.
        Spokane Heating - Spokane Air Conditioning
          James, Mo, Steve
          Thanks a lot for the advise. I open up the panel, and actually find the 3A fuse blew. So I replace it with the new 3A fuse. At first I have the T Stat set on AS, and Fan on. As soon as I turn on the disconnect, at the unit, it blew out the fuse again. Then I turn of the AC at the T Stat, and just set the fan run only. Replace new fuse, and the fan run again. Then I turn it to AC, and the fuse blew out again. . Any advise? At least I know that the motor is still good. Just don't understand why the 3A fuse keep blowing when I switch to AC mode at the T stat.
          Thanks,
          Tea
            Sounds like a mouse chewed through the insulation on the control wiring from the furnace to the condensing unit causing a short circuit. This is what I find 9 out of 10 times when the control board fuse blows on a call for cooling.
            James
              James,
              This is in the artic. If that is the case, I have to trace out where the bad control wire is? How can I check that? I did a stupid thing by try the 5A FUSE. Its start running again, for a short period, then stop. But I check the 5A fuse, it doesn't blow. I might of mess up the small transformer?
                You can check the wire with an ohmmeter. I find it easier to pull new contol wire. First check the compressor contactor coil winding for a short. This will cause the fuse to blow. The 5 amp fuse wasn't a good move. Check for voltage at the circuit board secondary voltage terminals. If 24volts isn't present you need to replace the transfromer.
                James
