Dual Port Auto Vent
  • Dual Port Auto Vent
    Anybody use one of these? opinions?
    Reading the discription I see a flaw but I want to hear from a user before judgement.
    Thank you
    Re: Dual Port Auto Vent
    Really need to remember to add pic/link before hitting that button...lol
    Amazon.com: Watts Brass & Tubular 1/8' Boiler Vent Valve Duo Vent 1 Valves Relief: Home Improvement
      whats the purpose? one is a auto vent the other manual?
        The best I can tell from the discription one side is ported larger to vent/purge a new start-up and then when pressure stabilizes with water in the main side it will seal closed. This leaves the small port active afterwards. A properly placed purge drain and a ball valve eliminate the vent for this purpose, but I have just never seen this before.
          i have never seen one like this and like you said all you need is a purge valve
            So this eliminates the cost of buying and installing a purge valve?
              Not if the unit seals it self after the first use. What happens a few years later when something needs to be replaced? A good system will always have all the right stuff in the right place. Cutting corners on a build will only cost a lot more later.
                Oh. I thought one could push the valve open for high volume while the other did in-service air bleed.
