Heat pump problems
  • Heat pump problems
    About a week ago I noticed my heat pump was not putting out heat. If I turn the thermostat up the auxiliary heat will kick on and it will put out warm air. But once it reaches a certain temperature it will begin to blow out cold air instead of kicking off. The only way I can regulate it turning on and off is to switch to Emergency Heat.
    Re: Heat pump problems
    Power cycle the thermostat. I had the same issue and that took care of it. Good luck.
      There's a problem with the outdoor unit. You need to call a service co. to check it out. Leave it set on emergency heat until it's repaired.
