Will Xcel Energy's Saver's Switch® harm our air conditioner?
  • Will Xcel Energy's Saver's Switch® harm our air conditioner?
    "It's a very cool program from Xcel Energy designed to manage air conditioning use during the hottest days of the year! Earn $40 easily. All you do is sign up below...you'll receive a $40 credit on your energy bill in October each year you participate! We'll do everything. Once you sign up, Xcel Energy will attach a small device to your central AC unit outside of your house that cycles it on and off for short intervals during the hottest days. You don't even need to be home for the installation."
    Your thoughts and advice?
    Thank you.
    Re: Will Xcel Energy's Saver's Switch® harm our air conditioner?
    Let them install it then bypass / override it
    Since they are a load limiting device I doubt they will do any harm... Normally they just break the low voltage control circuit to the condenser, the old ones were radio controlled but with the advent of digital electrical service meters and wireless reporting i imagine the technology has gone hitech.
    The systems are set up to load shed and load share during the highest energy usage times.
    A new house may be able to benefit from this technology but older systems have a hard enough time keeping up with the load so why cripple them.
    Xcel would save more money and overall energy by cleaning and servicing the equipment and leaving a few filters for the customer... IMO
      It's b/s....buy a programable thermostat instead.
        during peak usage and when they have to buy very expensive demand power, it allows them to shut off high energy using devices, (AC) and usually do on a rotational basis so it is not off an extended amount of time, it can save the power company thousands in demand power over usages, it is the same as if the thermostat shut the unit down (most likely),
        they had a program like that here at one time (maybe they still do) for irrigation pumps,
        Energy demand management - Wikipedia, the free encyclopedia
        if they think it will save them enough demand electricity, to rebate you a 40$ check at the end of the year, try it,
        (I would check in to the policy of the power provider, is to what it would be if your not liking it and want it unhooked, before signing up),
