Fix a flat
  • Fix a flat
    Ok, so it isn't really fix a flat. It is a stop leak that was used sometime a year or two ago on a buddies system. It uses R-22. He wants me to come out there tomorrow to see why his outdoor unit isn't coming on.
    Won't this crap screw up my gauges if I hook up to it? Could I possibly purge through my gauges with freon to avoid throwing away my gauges?
    AllurePlumbing.com
    • leak detection
    • drain cleaning
    • utility locating
    • conductor fault locating
    • and other specialties.
    Re: Fix a flat
    Nah, your gauges will be fine, it's a small quantity dispersed through the whole system, and you really won't be drawing freon back through them anyway.
      Re: Fix a flat
      So, they couldn't wait.....unit was tripped. Blah, blah, blah...contractor wouldn't pull in all the way. So, I push it in within a second of the unit starting and it trips the breaker instantly. I haven't worked on a heat pump in forever. Two of the three posts on the compressor should equal the third when ohming out right?
      AllurePlumbing.com
      • leak detection
      • drain cleaning
      • utility locating
        Re: Fix a flat
        No clue, but I'm just an hvac hack. I'd just check each terminal for continuity to ground, i you get that you've got a bad compressor.
        /shrug
          Re: Fix a flat
          C to R + C to S = S to R. My concern would be a shorted compressor winding or a shorted run cap.
            Re: Fix a flat
            I told them they need a new unit. The compressor has had it. Its a '96 Goodman 2 ton. I just figured out that you can get to the compressor by removing the panels where the electrical is located. Nice not to stand on your head.
            AllurePlumbing.com
            • leak detection
            • drain cleaning
            • utility locating
              Re: Fix a flat
              Yes and check each post to the case of the compressor (Continuity or OHMs on a digital meter). Always a good idea to get directly on the compressors terminals as sometimes your meter wont catch the ground from the compressor leads at the contactor to the condensers sheet metal case / electrical ground.
