Moisture
  • Moisture
    Any sling psychrometer and hydrometer brands you use and like?
    AllurePlumbing.com
    • leak detection
    • drain cleaning
    • utility locating
    • conductor fault locating
    • and other specialties.
    Re: Moisture
    Once you go Bacharach...you never go back.
      Re: Moisture
      I use their combustion analyzers and their combustible leak detector. Thanks.
      AllurePlumbing.com
      • leak detection
      • drain cleaning
      • utility locating
        Re: Moisture
        Psychrometer...fluke.
          Re: Moisture
          Actually have to have one for tomorrow. The only thing I can get by tomorrow is an Extech. Just found out today Flir bought them out not too long ago.
          This call I received today says a plumber was out already and couldn't find anything leaking in the house or crawl space. They had a test of the air quality done in the home and they found that there is mold spoors in the air. They have some mold near the bathroom too. I am guessing the a/c unit is sized too big and not pulling enough moisture out of the air. With it being the dead of summer and humid I am expecting 45-50% relative humidity if it were working correctly. What should I expect the inside of the house to be versus outside with respects to relative humidity?
          Any other thoughts?
          AllurePlumbing.com
          • leak detection
          • drain cleaning
          • utility locating
            Re: Moisture
            Who did this test? The concentration & type of mold spores?
            P.S. 90% or more of the bathrooms I go in have mold and mildew to some degree. And I'm willing to bet a generic air-mold spore test would show something at all of them.
            I smell mold remediation & disaster cleanup sales team!
              Re: Moisture
              I am not sure who actually did the test, they were very vague. They called off the job the day of. They said they didn't want to pay my fees for whatever equipment I would need to find the cause of their problem. I doubt they wanted to find out they needed remediation.
              AllurePlumbing.com
              • leak detection
              • drain cleaning
              • utility locating
                Re: Moisture
                im really old school. i prefer the psychrometer that uses 2 thermometers, the wet sock and the psychrometric tables. BUT, in a pinch i use this
                Amazon.com: CooperAtkins SRH77A E 3-ZoneTemperature/Humidity Tester [Misc.]: Home Improvement
                has lots of uses, including relative humidity and wet bulb sensors.
