Circulating pump on feed or return in residential gas boiler
  • Circulating pump on feed or return in residential gas boiler
    consider a conventional hot water, natural gas, cast iron boiler, single zone.
    When I was coming up, the old school guys always preached "pump into the boiler".
    Nowadays, the boiler manufacturers all show the pump on the feed or "pump away." Even B&G preaches this in their Little Red Schoolhouse classes.
    So my question is this: what is the significant advantage to "pumping away"? Safety? Better pull through the system? more efficient?
    thanks,
    -chris
    Re: Circulating pump on feed or return in residential gas boiler
    They will work fine either way if you pipe it to suit your pump location.
    AllurePlumbing.com
    • leak detection
    • drain cleaning
    • utility locating
    • conductor fault locating
    • and other specialties.
      Hit a button. Anyhow, you are trying to keep the pressure higher in the piping system. The system works better. Not to big of a deal with your scenario. There is o friction loss to speak of in a cast iron boiler. That's why it would be just fine either way unless you keep the pressure too low.
      Something else that people talk about but I have yet to experience is air being sucked in from air vents. It happens pretty easy if you don't replace and repipe with a bladder style expansion tank.
      AllurePlumbing.com
      • leak detection
      • drain cleaning
      • utility locating
        Swade, I was taught the same way as you.
        Either way will work though.
