New furnace, old glass fuse on cabinet ?????
  • New furnace, old glass fuse on cabinet ?????
    Most gas Hot air furnaces are protected with a 15 amp. dedicated breaker in the panel. Isn't it redundant to supply
    and old fashion fuse at the cabinet disconnect ?? Thanks
    Re: New furnace, old glass fuse on cabinet ?????
    maybe, but sure is handy when working on it.
      Tool, the key word in your post was "most".
        yes, it is redundant. however if the breaker is over sized, a local fuse/breaker is used. remember, too, that a fuse is a positive, 100% break when there is an overload. With a breaker it is not always the case.
          I don't understand anyone over fusing a circuit . 20 Amp breaker on 14 Ga. wire doesn't get signed off. It's stupid, a hazard.and against Elec. code
            Agreed.
            What I normally find is that the old unit that was replaced required a larger breaker and wire. Those were left in place at the time of the new installation and it is locally fused to the correct draw for the new unit.
            Edit: first post didnt take...
