Heating Costs
  • Heating Costs
    If all energy sources converted to BTU's had equal costs, what would be the best way to heat?
    Re: Heating Costs
    Approximate Heating Value of Common Fuels
    Natural Gas 1,030 Btu/cu ft 100,000 Btu/therm
    Propane 2,500 Btu/cu ft 92,500 Btu/gal
    Methane 1,000 Btu/cu ft
    Landfill gas 500 Btu/cu ft
    Butane 3,200 Btu/cu ft 130,000 Btu/gal
    Methanol 57,000 Btu/gal
    Ethanol 76,000 Btu/gal
    Fuel Oil
    Kerosene 135,000 Btu/gal
    #2 138,500 Btu/gal
    #4 145,000 Btu/gal
    #6 153,000 Btu/gal
    Waste oil 125,000 Btu/gal
    Biodiesel – Waste vegetable oil 120,000 Btu/gal
    Gasoline 125,000 Btu/gal
    Wood
    Softwood 2-3,000 lb/cord 10–15,000,000 Btu/cord
    Hardwood 4-5,000 lb/cord 18–24,000,000 Btu/cord
    Sawdust – green 10-13 lb/cu ft 8-10,000,000 Btu/ton
    Sawdust – kiln dry 8-10 lb/cu ft 14-18,000,000 Btu/ton
    Chips – 45% moisture 10-30 lb/cu ft 7,600,000 Btu/ton
    Hogged 10-30 lb/cu ft 16-20,000,000 Btu/ton
    Bark 10-20 lb/cu ft 9-10,500,000 Btu/ton
    Wood pellets – 10% moisture 40-50 lb/cu ft 16,000,000 Btu/ton
    Hard Coal (anthracite) 13,000 Btu/lb 26,000,000 Btu/ton
    Soft Coal (bituminous) 12,000 Btu/lb 24,000,000 Btu/ton
    Rubber – pelletized 16,000 Btu/lb 32-34,000,000 Btu/ton
    Plastic 18-20,000 Btu/lb
    Corn – shelled 7,800-8,500 Btu/lb 15-17,000,000 Btu/ton
    cobs 8,000-8,300 Btu/lb 16-17,000,000 Btu/ton
    Electricity 3412 Btu/kilowatt hour
      Re: Heating Costs
      If it was equal cost per BTU, (I think that is what your saying), what ever system was the most efficient and ever was easiest,
      I would think electricity would be the most efficient and easiest, if the cost of BTU was equal
        Re: Heating Costs
        I use wood and the most i used in one day was about 10 pieces and the temp is about 20* at night and 40* day time .
        I got 2 cord of wood for $400 this year because i just moved up here .Next year it will cost what ever the gas is for my chain saw because i have lots of trees to cut down .
        I dont need to go to the gym because i will be splitting the wood by hand so that saves me money 2 ways
        The house stays at 72* and drops to 65* at night and there is still hot coals when i get up in the morning
        We have a very well insulated house
          Re: Heating Costs
          i use 3 cord a year, myself. the differences being that my wood comes free...well, almost free. i barter trade services with my family for wood. most of the time the house is between 75 and 85 degrees. it falls to 69 at night. usage is about 2 five gallon buckets worth of wood a day.
            Re: Heating Costs
            With the heating costs of any septic drain cleaning , Garbage Disposals a $250.00 value !
              Re: Heating Costs
              SPAM with no links...hahahahaaa
