Dial or push button thermostats
  • Dial or push button thermostats
    If you have a boiler ,hot water heat with cast iron rads,do you have to use a dial style thermostat or can u use a touch screen or brush button type?
    you can use anything you want that is compatible with the control wiring.
      I would prefer the dial typefor its simplicity and durability, But as long as the thermostat can handle the control voltage you can use anything you want.
      coffee hell gimme booze!!!
