Mua
  • Mua
    I wanted to know what the differance was between a AHU vs MUA??
    I have both of them.They both deliver a/c and both supply heat??
    AHU = Air handling unit
    MAU = Make-up Air Unit
    MAU should be 100% outside air for mabye a ventilation hood or something like that.
    Regards
      Regards
      true very true
        Can you give more detail plz.
        etc:why use an AHU then?I have to of them.Is the internal disign any different?
          You will use your AHU because it is more economical to re-heat/cool air than to continually heating/cool outside air. But if you have an exhaust sytem pumping air outside you need to replace this air to prevent a negative pressure inside the building. The MUA unit will/ should be interconnected to your exhuast system.
