pro press vs sharkbite
  • #31
    Re: pro press vs sharkbite
    i want to reply to this one
    but not going to do it
    • #32
      shark bits are ok. yeah they are quick, but i dont think they can beat the PP system. We have 2 320-Es and one 100-B, we use them a lot. but most of all we use the newer style, the all copper ones, and not the brass. Saves a lot of time.
      westcoastplumber - you have a great point. You can cut a live (not at full pressure) and still crimp it. no brazing.
      5 Super Wal-Marts down and none to go.
      • #33
        I have yet to pick up a Propress. I have heard they have to be recalibrated after 20,000 cycles, is this true? I deal alot with PEX , but those fittings are pretty expensive. As far as Sharkbite stuff , its a great service call generator!!LOLI have been to numerous houses when home owners have tried taking HD employees advice then took the plumber matters into their own hands..Its great..
        Bill
        • #34
          Bill
          bill i have handfull of propress tools (1- 100/ 3-320/ 1-400)and shark bite.
          i typically initial and date all of my special repair work. i have yet had to come back to any propress or sharkbite repair.
          if the pipe is proprely prepped, reamed, there is no reason it will fail.
          • #35
            Bill
            Hey Bill, what part of Boston ya from?
            • #36
              Somerville/Cambridge..are you from Boston?
              • #37
                Bill
                Propress has it's uses, it is an excellent tool in a pinch, when the job calls for it. I have posted some good cases of this, where a propress cut the time of installation on a rushed project, or when a system can't be drained and it is an emergency timed shut down.
                Now, where I think that a propress shouldn't be used, would be to re-pipe a house. I know a guy that does all his re-pipe in pro press. I think it is a waste of skill for most of us (not him, he is probably better of using a simple system like pro press)
                The equipment made by ridgid is excellent, it is made well and very durable. The machine does have to be calibrated, but, on the other hand, all machines have to maintained to a degree.
                Robert
                • #38
                  Other then the PP crushes (Mechanical Joint) the pipe putting a dimple in the pipe causing the water to eat-a-way at the dimple because of the cavitations being cause with-in the pipe and fitting.
                  the Shark Bite is a Mechanical Joint and will fail in time.
                  I know you don't want to hear it but it`s all true. How long before they fail?? Who knows???
                  You just cant replace the old time tested pipe threaded idea
                  • #39
                    Ole southie boy here gone to the burbs...you undoubtedly know Mr Sillari, done alotta inspections with him in the last year or two.
                    Alotta old school plumbing in that area.
                    • #40
                      Well plumbers,looks like we're cutting out those thinwall copper fittings that we used the tin like solder on and repiping in threaded brass
                      • #41
                        Try another method
                        [IMG]file:///C:/DOCUME%7E1/Phyton/LOCALS%7E1/Temp/moz-screenshot.jpg[/IMG]
                        http://www.t-drill.com/t60.html
                        • #42
                          I'm experiencing a strange subliminal urge to buy a T-drill, it's overwhelming, can't fight the urge.
