Soldering w/ oxy acetylene
  • Soldering w/ oxy acetylene
    I was giving my new torch a whirl today(thanks Bill) brazing some 3/4" pipe and decided to try soldering with it. I was using a captain's hook tip w/ oatey #95 and silver solder and it worked great. Took 4 seconds per joint. Has anyone tried this? Any disadvantages besides the added cost of fuel? At 4 seconds per joint, it doesn't seem like much fuel is used.
    Re: Soldering w/ oxy acetylene
    cost of set-up and weght
    how is it that so many answers are in the instructions
      uh, careful in a tight spot, one little delay getting solder to the joint and you will risk burning the flux, causing a void in the joint.... from experience...
        Agree.
          O/A will make copper melt like solder if you arn't carefull
