pipe threader
  • pipe threader
    thank you all for the help and think am going with the hand held threader found one for a good price. do i need a special pipe cutter or can i use a sawzall for now or will it not make a strait cut. thank you
    Re: pipe threader
    I would recommend a ridgid pipe cutter and a reamer, I have had off brands and they don't work near as well. even if you buy a used cutter, and if the cutting wheel is messed up replace it, there not that badly priced,
      Re: pipe threader
      The Ridgid cutters are all over the place on E-Bay for cheap.Even if you have to get new wheels.This will save you money you can put towards the reamer you will need.
      Good choice,you saved youself a lot of money.I've hand threaded a lot of pipe,it is not that bad.
        Re: pipe threader
        Adam you forgot to mention from your own experience to look at users ratings before purchasing right?
          Re: pipe threader
          I have cut all my gas lines with a sawzall and a 812r sawzall blade. You have to be carefull not to cut crooked, the good thing about using a sawzall is that you do not have to ream out that much to get the full bore of the pipe.
          When you use roll cutters it tends to leave a ledge on the inside and the outside of the pipe.
          Robert
            Re: pipe threader
            Chop saws work great,They are just real messy.It's hard to get all the dust so it doesn't rust the owners property.I still use mine when cutting for the Amigo 2.
              Re: pipe threader
              I do this as well, much faster.
              Also, the roll cutters will sometimes make it real hard to get the dies to grab and hold to start a thread on the end of the pipe.
              Can make hand banging threads pretty uncomfortable.
              I've never owned an electric threader; been doing it manually my whole career and what kept me from ever buying a 300 was the reason my idiot self had to be the one who always dragged that into every job over huge mud ruts to new construction jobs when I first got into the trade.
              Part of being a new hand in the trade. Tore my rotator cuff earlier this year and I swear the exercise with my threading tools brought my shoulder back to 100%.........
              Okay 90%
