Copper joint preperation
  • Copper joint preperation
    I've been using a Norton #746 pad (I looked it up Adam)to clean the outside of my pipe. Bought at HD(in paint section) but forgot the price, this stuff lasts. No BS, I must have done about 400 joints with one pad. It comes in a 2 pack and I haven't used the other pad yet. The same pad shines the joints up after soldering. Just thought I might share.
    Re: Copper joint preperation
    We use to use Prep-Star copper machines and they had similar pads for cleaning the copper. They lasted a long time as long as you copper was real clean.
      Thanks for the tip. I'm going to try it.
        You can get pretty good life out of scotch brite pads also.
          Ben, where is the picture??? I am waiting.....
          One thing I can say is ProFlo sandcloth sucks.
          Robert
            Both the plumbers and the fitters use the Norton #746 at this shop we use a old 9.6 Dewalt cordless for cleaning fittings as well
              I do the same with the drill. Works very fast.
                Ben, is this the pad you said you got at Home Depot? If so, do you have any sort of number I can use to track it down at Home Depot with?
                Thanks.
                Proud To Be Union!!
                  http://www.nortonconsumer.com/Data/E...00000000001562
                  I think this might be what you're talking about. This is the norton equivalent of medium grit steel wool. I usually use medium steel wool or open mesh cloth (oatey or masters). I know a guy who uses these and apparently they work faster and last longer than grit cloth. I like grit cloth cause you can rinse it our and it doese'nt fill up with dust quickly. Ill go pick up some of this stuff though and try it out it looks like it would work good especially on large diameter copper. Thanks and I hope my link helps!
                    erm... it's proflo, you get what you pay for.
                    /stirs the pot and darts away
                      It's 6: 24 Sun. Morn, My day is made! I see that Blue and white Van. Tool
