460 Pipe vise
  • 460 Pipe vise
    Question I just bought a 460 and the support tray below the working area does not lay down flat when its unfolded as in the picture, I had Reed pipe vise for years and it laid down flat, am I missing something? this vise came assembled from Grainger?
    Re: 460 Pipe vise
    One of the set screws on the inside of the leg needs to be loosened and the tray should lay flat. Then retighten
    hope that helps
      Re: 460 Pipe vise
      Just in case you need-want it, here's the parts list. This may come in handy later on. Good luck getting it setup correctly and please post an update.
      Update: 04/11/08 at 9:51pm EDT
      I blew it, I blew it. I posted the wrong file again so I removed it.
        Re: 460 Pipe vise
        Thanks I got it to lay flat but it is not straight? Tried forcing the side with the set screw up but it still will not get level
          Re: 460 Pipe vise
          Wrong vice Woussko but nice try
          Look here:
          http://www.ridgid.com/ASSETS/F5FFFF2...in_Vise_PL.pdf
          The problem may be that Grainger assembled it improperly. Look closely at the diagram. Is the set screw on the rear leg and not on one of the front?
            Re: 460 Pipe vise
            PC
            Thanks for fixing up the mess. I had too much Hush Hound #3 and that stuff makes me get strange. No more of it for me. From now on I'm going back to the original Hush Hound.
