Pipe Threader for Rebar
  • Pipe Threader for Rebar
    Hi;
    New to the the Blog.
    MY question is can the Ridgid pipe threaders be use as to thread
    # 3 and # 4 rebar.
    If they can do you know what the models are as well if the portable ones.
    Thank you
    Dan
    Re: Pipe Threader for Rebar
    dan, i thought at 1 time i've seen it listed. but i can't find it now
    is rebar actually round? can you grind off the ribs and then just use a regular 3/8'' or 1/2'' bolt thread?
    i don't see any way of threading with the ribs on it
      there are commercial re bar end threaders that are tapered, and special machines as well if on could get the die from one of the manufactures and then I would think one could adapt the die to a pipe threader if that was the case,
      it appears to form the re bar in the process of threading, as it appears tapered in form of the threads,
      http://www.erico.com/public/library/Concrete/LT0426.pdf
