plasti-bond threading
  • plasti-bond threading
    I have Ridgid model 700 pipe threader we got a job that specs plasti-bond pvc coated rigid pipe. can i use the threading dies on this pipe or do i have to buy different dies?
    Re: plasti-bond threading
    Your 700 is just the power head, what are the model numbers of the dies you are using?
      pvc rigid coated pipe
      do i need special die to thread plasti-bond pvc coated rigid conduit?
        Re: pvc rigid coated pipe
        Are you threading this by hand or on a threading machine. By hand you need a different diehead the dies are the same but the OD of the plastic coated pipe is bigger than regular 2" pipe so you need a special head. If you are doing it on a threading machine there are dies for pvc coated pipe and jaw inserts so you don't leave teeth marks on the plastic.
          You need the 12-R dieheads for plastic coated pipe. What size are you doing?
