316 Stainless Threading
  • 316 Stainless Threading
    Just wondering about the best method on threading 316 ss, we have made many threads, but with inconsitent results.
    Thanks
    Re: 316 Stainless Threading
    Got dies for stainless ? What type of die head ?
      please be specific on the methods and machinery you use as well as the sizes you are threading. it may be the speed of the machine and perhaps the threading oil you are using.
      http://www.blackbookoftools.com
      http://www.gronim.com
        We are using a 2" 12R with HS SS dies, Ridgid dark oil, will get about 10 or 15 thds max out of a set of dies, also have used 67R threader with HS, SS dies, that seems to be a bit better, but die life is still short, all these powered by 700 power drive.
        Thanks
          Thanks
          the dies are #37550 for 2'' hi speed stainless correct?
          the oil should be their newer "extreme performance oil"
          "high performance mineral oil formulated to produce superior quality threads on stainless steel and black pipe"
          1 gallon part # 74012
          do you have access to a bench top machine like a 300 or a 535?
          the 700 is a great machine, but 2'' stainless is really pressing it's limits and you will have more consistent results with a bench top fixed chuck and die head.
          the rpm is 32 no load on the 700
          38 rpm. on the 300
          the 535A has 3 spindle speeds and 16/46/58. my choice is 16
          the 535 is 36 rpm.
          hope this helps.
