What did I buy?
  • What did I buy?
    I just bought a Ridgid #102 lathe-type tubing cutter
    I thought it might come in handy somewhere.........but where?
    Who has one and where do you use it?
    Re: What did I buy?
    Me too, still haven't used it.
      Re: What did I buy?
      Get rid of it then guys. One week later then you'll have a need for it. Happens almost every single time....
        Re: What did I buy?
        does it count if i have 2
        use them to cut flush to a wall or inside a wall.
        even to cut off an angle stop ferruel flush to the ring
        when you need it, you need it
        keep it oiled and it will be ready when you need it.
          Re: What did I buy?
          I actually used my seasnake micro today.
          Bought it 6 months ago after I was on a job where I really coulda used it.
            Re: What did I buy?
            I use my micro all the time for hvac work. It has got to be the best thing since sliced bread for peeking into heat exchangers, and if you do oil burners you can actually see the retention head withoug taking the burner out. Can't wait for the new version to come out. Only thing is I wish the cable was maybe 10" longer.
              Re: What did I buy?
              Did you know you can get a 3' extension cable for it? You can also use multiple extensions up to 30'.
                Re: What did I buy?
                It finally happened. The offices that I'm finishing. Cooler rough in, supposed to be Elkay turned out to be Oasis. That's another story. The owner/wife/interior decorator/secretary gal decided that there was to be no drinking fountain instead opting for the water fall art piece and changing yet once more for some big honkin' mirror. It mounts flat against the wall.
