3/16" brake line work - questions on tube cutting, bending, flaring
    Re: 3/16" brake line work - questions on tube cutting, bending, flaring
    Looking forward to it.
      IN my experience the 37 degree are single flare, and some times called JIC, or military or AN flare,
      SAE J514, 37° Flare (JIC)
      Commonly referred to as 37° JIC, this connection is widely used in hydraulic systems. When the straight threads are engaged, the 37° male seat seals on the 37° female flare seat. Most thread sizes are identical to the 45° SAE connection as noted (*) below. Care must be taken not to confuse these two connectors, which have different seat angles.
      http://www.fittingsandadapters.com/saej537flarj.html
      and the double flare is a 45 degree, and many times referred to as a SAE flare, (even tho most flares have a SAE specification)
      some times referred to as an Inverted Flare, I think more so for the fitting used, http://www.discounthydraulichose.com...ings_s/241.htm
      some interesting reading on brake lines,
      http://www.dimebank.com/BrakePlumbing.html
