What tools to buy. Page Title Module
  • What tools to buy.
    We're ramping up to do some heat exchanger production. Most things are copper or bronze. Most are between 1" and 1 1/2" fittings. The finished product must look nice and not be scratched up.
    We're going to get a Ridgid 122 copper cutting/prep machine and some hex pipe wrenches.
    What do you think of the model RT-175 flameless soldering gun?
    Is it good for production work?
    Is it very fast?
    We don't want to scar the bronze fittings when threading them. For those fittings that don't have hexes on them, what's a good way to tighten them?
    Usually strap wrenches slip, is there some that are better than others?
    Will a chain wrench gouge the fittings.
    Todd
    Re: What tools to buy.
    Is this a joke?
      Please hire a plumbing contractor!!
        no scratches with sharkbite....
        The Other Rick
          Nope. No joke. I wondered the same thing at first. This is very preliminary research.
          A plumbing contractor? It's production work.
          Sharkbite is great, but we're dealing with "copy exact". That is, we have to make this look exactly like the stuff that's already been installed. Exactly.
          So, what do you know about the RT-175 flameless soldering gun?
          Todd
            Production work using RT-175?
            Can you use a Ridgid RT-175 flameless soldering gun for production work on 1" copper?
            Is gas going to be much better/worse?
            Todd
              Re: Production work using RT-175?
              i tried out a competitors electric soldering tongs.
              i was going to buy them for a 155 unit repipe.
              fortunatly i purchased 1, tried it out and decided against them.
              they are not all their cracked up to be. the carbon tongs remain red hot for some time and the carbons to wear.
              i wasn't impressed
              now if you want impressive and super fast production
              purchase a propress machine. nothing like 4 second joints in a 1/2''-4'' connection. no cleaning, flux, or torch. plus no leaks
              the new propress model #330 is the ticket
              i don't own this model yet
              but i do own 5 others 1-100 b, 3-320 e, 1-ct 400.
                The 330 will get you into tighter spots---especially if you buy the swivel jaws----and hes right-no leaks
                if you are doing lots of joints--id buy the press---it will save u tons of time and material and leak detecting time and no wasted units due to bad fitting soldering
                  If you want to solder a lot of joints for production, use oxy acetylene and captin hook tips.
                    Todd , I'd like to help. Need more pork on the fork. You'll like my GO FAST
                      Oatey #95 does the same thing.
                        Thanks for the input.
                        Todd
