Propress impress
  • Propress impress
    so i had to replace a leaking soldered 1'' gate valve today and the problem was that there was no play or room in the system to add a slip coupling or union.
    so how did i do it
    this is a 1'' copper water service that comes out of the concrete and into a stucco wall.
    as you can see it's tight and i didn't jack hammer the concrete or chip the stucco to make room.
    all i did was replace the 90 and the valve.
    so how did i do it
    there is no play in the line to assemble the fittings.
    so how did i do it
    please explain, then i'll tell you when you're right
    Re: Propress impress
    Unsweat the 90/Gate Valve and disassemble the ball valve.
        he cut the copper under the gate and at 90 and pressed it in
          rick--why are u using viega knock offs????? havent i heard u talk of only viega fitts?????
            Exactly...
              rick, i can't comment on your questions because i'm not familiar with propress. infact i haven't even seen it spec'ed with the new construction up here.
              i do have a question though, what's the PRV for?
                Cut that 90 with a diamond blade angle grinder in the turn of direction
                Unsweat the leftover piece on the pipe leading to the main along with unsweating the gate valve.
                Clean the two pieces of pipe exposed, work the new ball valve in with a new 90 along with the short pieces of copper pipe.
                I promise I could of done it faster and in a far more tighter situation, for which that situation is in the wide open.
                Given what your pictures are indicating, you are nearly at the tolerance of your fittings, any shorter of a distance and this thread wouldn't even exist.
                  needed to cut the copper under the valve to allow to drain and unsweat the 90.
                  issue was not removing the old, but fitting the new in. there is no room for any slip coupling or union. there is no movement in the lines.
                  this is a "cim valve" much better than the viega valve. the fittings are all viega
                  back in 1983 they allowed the prv on the service instead of needing one on the heater. pressure is still below 80#
                  no pipe was added as there is no room to add any pipe.
                  only used the valve and st90.
                  dunbar, i know for a fact that soldering was not the way to go. this a 2 story house and no access to drain anything above. noting to drain below the concrete as the meter is also in a concrete box.
                  Given what your pictures are indicating, you are nearly at the tolerance of your fittings, any shorter of a distance and this threa wouldn't even exist.
                  exactly. the propress fittings and valves are larger than solder fittings.
                  what i'm looking for is how did i piece this together with no play/ movement in any of the exisiting piping.
                  no one is close yet
                    no one is close yet
                    What makes the cimpress valve superior?
                    Greg
                      greg, there are a vew reasons.
                      look at that metal handle. it actually has a slot cut into the handle to allow it to be locked on or off.
                      you remove the handle nut, pull the handle off and install it back onto the valve locking onto that position.
                      the cost is lower
                      and if i told you everything right now, i might give the answer away
                        Can you slip through the ball?
                          no. but good guess.
                            The couplings on it look deeper & away from the valve like you could slide it up down and still get the proper crimp. Other than that, I'm willing to learn.
                              disassemble the top of the ball valve, slip it up on the street 90, swing it down to the pipe to assemble, then tighten the ball valve back together. Then press.?
                              The Other Rick
