tips for apprentices
  • tips for apprentices
    okay guys.
    even if this thread has been posted before, it's still important for us with experience to teach and pass on our knowledge.
    do you use a method today that was taught to you?
    ie; preheat the frozen wax seal before setting wc
    or
    have you figured out a method of doing something that isn't written in any book, something you learnt on your own?
    ie; don't position yourself directly under the solder joint your doing.
    Vince
    i get paid to get dirty. i love my job!!
    Re: tips for apprentices
    That the Turbo tip does an excellent job of drying out my frozen wet boots without having to take them off.
    Inside a toilet tank is a great place to find a cold beer during the winter
    Don't flip anyone off in traffic while in the company truck. It just might be the bosses wife
      i need to meet you!!
      Vince
      the scary part is i like the way we (e) think
        Sometimes I use the defroster in my truck to warm up wax rings before setting a toilet in the winter time. If the toilet rocks a bit I use 3/8 pex for shims. Works great never rots or rust.
          After a job well done.Get out on the Lake.Oxford/Batesville is a lovely place,and the County football team is GREAT.
          Kenneth Collier
          Maintenance and Sewer
          P.O. Box 9441
          Jackson, MS 39206
          (601) 613-2678 (Cell)
          drainman881999@yahoo.com
            Vince
            Well, put on your Mukluks and come down to the Ridgid Roundup in Ohio next September. I'll be there and so will most of the other Ridgid Remarkables
            Hey Vince, where can I get a size 10.5 Mukluk anyways?
              how do you smile and wink at a seal?see attached pic
              getting out of here is some what pricey. i might be able one of these years. it really depends on work. i've been hungry before and so i take any and all work that comes my way, wearing a big eskimo smile too.
              as far as the kamiks (that's what we call them) are concerned there might be just a little problem with that.
              it's not a problem to get the exact size. you trace the actual outline of your foot. the problem is what they're made out of. seal skins.
              i don't think they'll allow them across the border.
              also, while the kamiks hear are very beautiful, functional, and quite expensive ($300-$500), the smell when they get warmed up smells like,........well, a seal. some people may not appreciate that.
              i can however try and help you out. i've worked for this company below. really nice people.
              http://www.arctictradingco.com/
              Vince
                soldering tip
                when i solder a joint, i keep adding solder until the little air bubbles stop spitting out.
                then i know the joint is full.
                i believe the bubbles are from the air expanding inside the pipe when we heat the joint with the torch.
                Vince
                  Well worth the money......
                  http://www.mukluks.com/
                    save
                    your old socks
                    and
                    t-shirts
                    they make great rags.
                    thrift store t-shirts are cheap.
                    Vince
                      removing ABS glue from hands
                      i don't know what it's called but it's the black open weave (water proof??) sanding sheets used by the mudder guys. the kind that fits on the sanding block.
                      under running water it removes abs glue from the hands.
                      i stumbled on this one by accident.
                      Vince
                        emergercy wound dressing
                        i used a piece of a sock (clean of course) with electrical tape.
                        if your wound or cut doesn't bleed, squeeze it and make it bleed. it might flush out any foreign matter.
                        Vince
                        i put my camera and clean sock rags in zip locks to keep them clean
                          I use a small hose to trickle hot water into frozen kitchen sink drains to open them up.
                          Is this the girl from your link?
                            she's my ex. too many issues and high maintainence.
                            Vince
                              Tips for apprentices.
                              Buy good hand tools. They'll last you a lifetime.
                              Be honest.
                              Always try to improve the product and the process.
                              You don't know that much because you did a job on your own and it passed inspection.
                              When you stop thinking is when you get hurt.
                              Respect other trades.
                              The copper is hot.
