Tight Crimpers
  • Tight Crimpers
    Are my crimpers too tight? I've had some say they couldn't squeeze them.
    Re: Tight Crimpers
    that's a funny looking gear clamp.
    Vince
      Re: Tight Crimpers
      This is what happens when you don't have the press tool aligned correctly. Then you have to cut it out and do it again.
      Turned out to be a good thing. I didn't notice I had the wrong ring on the first time.
        Re: Tight Crimpers
        This is what did it.
        It was basically a "blind" crimp in a small hole. I started the crimp but something just didn't seem right. The jaws weren't completely on. Only took about 1 second then I had to start over.
          Re: Tight Crimpers
          do you mean to tell me you can you your press tool for pex crimp rings...or am I on glue?
          West Trail Mechanical Ltd
          www.westtrailmechanical.ca
            Re: Tight Crimpers
            Yes they make jaws for PEX or Copper press fittings. Different jaws for each type of pipe.
              Re: Tight Crimpers
              WTH J.C.?
              You bought a Rothenberger crimper and didn't tell us?
              How do you like it?
                Re: Tight Crimpers
                This IS a Ridgid site & some have been very negative toward competitors products. So I'm reserved at mentioning other companies.
                But this "off crimp" was interesting and kind of shows the pressure all press tools can exert so I thought it might be an interesting post.
                It's not fair for me to compare which is better as I don't own them all. I am familiar with designs and breakdowns of all of them though. (I think...duh...)
                Some don't even know how many different brands are out there. Last I checked:
                Rothenberger-3 different models
                Ridgid-3 different models
                Nibco-2 different models
                Stanley Virax-2 different models
                I like the tool. Does what it's supposed too without leaks thus far. All fittings are approved to be used with it and carry the same warranty.
                This is the smaller of Rothenbergers line and will only crimp up to 1". (Maybe 1 1/4". I'd have to go get the book.)
                So far in my reading Ridgid has done some of the best R&D out there with there tool. I'm still researching all of them though. Some look so similar and use the same power that they look like they could come out of the same factory. But....
                I like this design MUCH better. The head rotates 350 degrees. Pretty much covers 99.9% of positions you need. Light, easy to hold, and you can get into much tighter places.
                Crimps PEX or Copper. About a 6 second crimp cycle.
                Overall, a good choice for me. But NOTHING beats a soldered/brazed joint in my opinion.
                  Re: Tight Crimpers
                  I was hoping you were talking about the compact crimpers. the last pair of 3/4 crimpers I bought are really hard to squeeze together. I guess I could just be getting week. Have noticed this?
                    Re: Tight Crimpers
                    Compact MIL3 crimpers are harder to squeeze in cold weather in my experience.
                    Honestly, two or three different people have tried my 1/2" ones and can't squeeze them. I can.
                    But I'm scared they might be out of calibration and I might need to have them checked soon.
                    But I also might get lazy and just use this all the time.
                      Re: Tight Crimpers
                      I've also had new 3/4" crimpers that were almost impossible to squeeze. Took awhile for them to wear in to be tolerable.
                      Talked to a guy the other month that said he put cheater bars on both handles.
                        Re: Tight Crimpers
                        Shouldn't a standard go/no-go gauge be able to check the calibration of the machine?
                          Re: Tight Crimpers
                          Yes, but you can get a "go" with crimpers that are too tight. Just makes me wonder if being too tight could fatigue the joint in some way. And I'm talking about my hand crimpers. Not the press tool.
                            Re: Tight Crimpers
                            now if you really want a crimper to fit in a tight space, try the new c-1 compact crimp swivel rings. this will turn your 100-b compact crimper into a real swivel crimper.
                            sort of like what a universal joint does to a socket set. it will allow the tool to crimp parallel to the pipe and any angle in between.
                            look at the link.
                            http://www.ridgid.com/Tools/ProPress-Rings
                              Re: Tight Crimpers
                              look at the link.
                              Just to add a footnote to the C-1 swivel crimp rings. It will increase your 100-B compact crimper up to 1-1/4"
