Viega Pex Press Sleeve removal
  • Viega Pex Press Sleeve removal
    Viega Pex Press Sleeve removal tool? Can't find one listed. I have pex crimp ring remover tools but I want one for these stainless sleeves for my propress system. Any help thanks in advance.
    Bryce
    Seattle Drain Service
    Re: Viega Pex Press Sleeve removal
    Wow nobody has needed a stainless press remover? Even if you never made a bad press I have picked up others scraps and want the fittings! I had no problem removing the stainless and saving the fittings but it was slow with my hand tools. And the manual says use a heat gun tried it seemed slow also. Guess I will start using my plasma cutter
      hey there,
      the only thing i use is my torch and "boil" the plastic out.
      although i don't do this often enough to need a better way.
      Larry
        I use a pair of compound tin snips and cut the crimp off, not an easy squeeze but it works.
