It Is Technically Pipe
  • It Is Technically Pipe
    Just some sched 80 1.5" aluminum PIPE railings, all TIG welded.
    They are going to a water treatment plant with lots of SS pipe
    Here is what we are making them from, 1.5" Sched 80 6061 aluminum
    The saw, look a RIDGID shop vac
    The coping machine
    The first rail
    Re: It Is Technically Pipe
    Will it hold pressure?
      Nice looking fab work. Are the stairs already in place or did you figure rise and run from the print?
        Nope pressure is bad, 1/4" holes drilled in every pipe both ends for anodizing or else it will balloon when they dip it.
          Built from prints, along with the stringers
            Here are a few that are done
              that is beautiful,
                In shop pre fab before we go install this set.
                  Real nice work
                    Sweet!
                      this ish is straight gangsta son!
