propress on soft- tempered copper
  • propress on soft- tempered copper
    anyone use propress on soft copper?
    Re: propress on soft- tempered copper
    propress is rated for up to 1.25'' on soft copper.
    hardest part is getting the copper round in the larger sizes to get it to push onto the fitting.
    there is a search feature and you can type in propress and research everything on propress.
    also you can look into the "viega" website for fitting info.
    ridgid makes the tools and viega makes the fittings.
    welcome to the forum.
      Thanks for the info- I just found the info on that site.
        I have pressed 1/2"-1" soft copper many times with good results, but like Rick said the biggest problem is getting the soft copper round enough to get the fitting on. My 2cents.
