Pipe Freeze Kits
  • Pipe Freeze Kits
    Ok guys, I need opinions, whuich I know a lot of you have here
    I need to buy a freeze kit, There are 2 in mind, Ridgid, which is refer type and then there is Generals, which is CO'2, which they claim freezes the pipe faster up to 2".
    Which is better or worse..... Pro's cons, Generals looks like it will store on
    the truck easy, As long as there is a short CO'2 tank, also what happens if I run out of CO'2 in the middle of the job..... but what if the refer breaks in the Ridgid.....so lets hear it.....
    http://www.ridgid.com/Tools/SF2500-Pipe-Freezer
    General
    http://www.drainbrain.com/specialties/coldshot.html
    Thank you in advance....
    Robert
    Re: Pipe Freeze Kits
    We'll see what Rick sez!
      Depending on the job the General kit is good but you really need 2 people to use it to change the tank if the job is long. So Robert do you have a guy to sit there and monitor the tank? Or if it is just you then the Ridgid wins as it sits there working till you turn it off.
      Seattle Drain Service
        i own plenty of the bag type kits with co2 and 3 of the ridgid super freeze.
        the original sf2000 and 2 of the newer superfreeze 2500
        the co2 is a colder process, but also a more involved process. you need to transport heavy co2 tanks and then if you're in a confined area, you need to worry about lack of oxygen as the co2 will displace the oxygen.
        i always go for the ridgid unit first, unless it's above 2.5'' copper on the 2500.
        the bags are a much cheaper investment, but the ridgid system is an easier to use unit. no tanks to carry and no worries about running out of gas.
        the 2000 unit i believe is no longer made. the 2500 is its bigger brother.
        freezing pipe is not something you want to guess at. you better know when it's frozen and when it's flowing
          Rick call this a Dumb question if you would like but what would you need to freeze a pipe for? I have just never run into this and am curious? Thanks
            you freeze a line if you cant get a shut off and there is still water in line
              When you need to install a valve or isolate a leak etc and you cannot shut down the building.
              In this case I am replacing a water fountain and changing an isolation valve out and cannot shut the building down due to heavy commercial use.
              Robert
                Thats Awesome!!! Thanks guys.....
                  In a pinch a fire extinguisher works well
                    yes it will as it's liquid co2/ dry ice.
                    you could also go buy some dry ice and wrap it around the pipe with a towel. much cheaper investment than all the specialized equipment.
                    small pipe is simple. large pipe is difficult. you also need cooperation with the downstream users.
                      A 20LB LPG bottle turned up side down works even better
                      Tony
                        Tony
                        That's how my mates cool there beers down.
                        Simon
                          Old timer I know, tank driver in korean war, used to cool beer with the tanks fire extinguisher.
                          One day the tank caught fire.............................
                          (true story)
                            but at least they had cold beer for the weiner roast.
                            G3
                              I've never heard about wrapping it in a towel. How long does that take to freeze? There is an article on this dry ice website that says to make an insulated box with dry ice in it... and that takes 10 minutes to freeze up. That is interesting, because a towel would be quite a bit easier! thanks!
