"that's so pretty"
  • #46
    Re: "that's so pretty"
    Back on topic. When using a 2" slip ProPress Coupling do you have to beat it back and forth with a hammer on the edge to get it to move into position?
    I know, no lube.
    that's the great thing about propress. you don't have to fight tight fittings. these things will literally slip into place by themselves. that's why it's important to use a sharpie to mark the joint depths.
    i thought you have a pressing tool already
    • #47
      I do. Would you believe there is not 1 Press Fitting at any supply house in my area right now.? Not 1. Gets more use on PEX....
      And for whatever reason, I don't run into many of the press situations that you do or maybe I don't think press first. Why would I? Can't find the fittings.
      • #48
        Go to pexsupply.com and look in the copper propress fittings. Do you have the copper jaws JC?
        Seattle Drain Service
        • #49
          Yes.
          • #50
            im not a 100% on this but i dont think you can solder it under ground here ,i think you would have to flair it .
            i will ask someone if pro press can be used to
