pvc cutter
    Re: pvc cutter
    Absolutely.
    I wish they had these when we were doing hundreds of cuts a day in production venting.
    The chop saw in the eighties ended up being to slow do to the miles walked per footage.
    I still use the skilsaw when topping out but the deburring step,no matter how minor,is still a step eliminated with this new uncorded tool.
    I'd own one if I was in production tract/residential.
      Re: pvc cutter
      How many cuts will it take to kill the blade I know cutting p.v.c. with poly cutters will kill the blade in no time and I bet these blades are a good bit. I saw this tool at ferguson's the other day well an ad for it on display and it says "one charge will cut x amount of pipes" and how many times did they change the blade?
        Re: pvc cutter
        [/B]
        Put a man on a chop/mitre saw and call out measurements like your life depends on it.
        That.s what we do. Or we use tubing cutters with a plastic cutting wheel. Or we use a hacksaw. Some guys even use a cordless circular saw/grinder. That thing just looks like my pex cutters on steroids. Pretty cool though, nonetheless.
          Re: pvc cutter
          here is the real deal and it will do more than p.v.c. and it is only $70.00
            Re: pvc cutter
            Need cordless
            Seattle Drain Service
              Re: pvc cutter
              they make it but I think I'am done with cordless too lazy to charge the stuff up. 120 volt outlet never lost its charge.
